Team Magic的M8 1比8越野车又推出新变种,名叫M8JS,这是低价的版本。厂方宣称这是市面上性价比最高的越野车,很多配置和M1B差不多。车子出厂已经装配妥当。
Features: - Super Impact Resistant - Lightweight.7075 Aluminum Center Drive Shaft - Extra Long Big Bore Shocks - Extra Long Suspension Travel - Large Receiver Box - Adjustable Wheelbase - Adjustable Rear Upper Linkage - New Generation Dimension - New Style Low Profile Slim Body - Quick Release Front/Middle/Rear Gearbox - Quick Release Fuel Tank - Low CG design
Specifications - 1/8 4WD Gas Buggy (Factory Assembled, but not RTR) - Weight: 3450g - Length: 501mm - Width: 305mm - Wheelbase: 320~328mm - Gear Ratio: 10.868:1
