AE RC8e电动越野车
09-3-6 12:53| 发布者: jovi| 查看: 3291| 评论: 2
Team Associated继RC8Te和SC8e之后,推出RC8e 1比8电动竞赛级越野车。车子基于优秀的RC8平台。针对电车的特性,AE开发团队特地对车子做了开发,使其强度、耐用性、过弯能力和操控性都与油动的RC8很类似。
RC8e Kit Features:
- Molded battery tray supports two ROAR-approved 1:10 scale size 7.4v LiPobattery packs with room for foam pads
- Receiver box, servo, and battery tray are removable in one piece for easy maintenance and cleaning
- Convenient wire routing keeps critical electronic wires out of drive-train components and simplifies disassembly
- Includes pinion gear (15T) and molded composite spur gear (46T)
- Rigid one-piece motor mount utilizes standard motor screw mounting pattern
- Large elevated speed control mounting area allows for easy screw mounting of common speed controllers
- Upgraded dual bellcrank steering for more consistent steering and reduced bump-steer
- 16mm “Big-Bore” molded composite shocks with preload clips
- Hard anodized 7075-T6 aluminum chassis
- 3mm aluminum shock towers
- Durable 10mm thick suspension arms
- Rear molded CVA boots to keep dirt and mud out of rear joints See next page for more features!
- Alloy steel turnbuckles
- Caster blocks adjust 14, 16, or 18 degrees with molded inserts
- Adjustable suspension pivot bushings for different pivot height options
- 4.30:1 ratio gearboxes
- 3.5mm light CVA drivetrain
- Pre-drilled wing with adjustable angle and location
- Blue aluminum drive hexes
- Blue aluminum nylock wheel nuts
- 83mm Factory Team wheels (#89296)
- Speed control mounting area includes convenient switch-mounting boss
- Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray
- Enclosed receiver box to protects electronic components
- Unpainted RC8e body with cooling scoops (#89523)
    引用 biao-xiang 09-3-13 14:56
    挺不错的啊。。 biao-xiang.com 飙翔模型
    引用 yeapple 09-3-10 23:10
    AE有新出的后驱车吗?
