Hot Bodies 为 D8 和 D8T 推出新升级零件
09-4-1 01:15| 发布者: admin| 查看: 2848| 评论: 0
Hot Bodies(HB) 的D8越野车和D8T卡车上市后受到不少玩家的赞赏,尤其是D8夺得世界冠军后,更证明HB也能做出世界级越野车,近日HB公司推为D8和D8T推出一些升级零件,进一步增强车子的战斗力,国内的玩家相信很快也可以在RCFans特约商家处买到以下升级零件。
67211_01
轻量化差速轴(2pcs) HB D8. HB D8T
Increase the potency of your D8 buggy and D8T truggy with special machined lightweight parts. Made from light, high-strength metals and strategically milled out to reduce weight in non-critical areas, you can drop some serious weight exactly where you need it while maintaining the integrity required for a stiff racing chassis.
Drop the weight and pick up those tenths of a second you need on the track!
67210_01p
加高油压架 (112mm)
67203_01p
Lightweight Steering Bushing
67202_01
Lightweight Shock Stand Off
67200_01
Lightweight Differential Shaft
67198_01
Lightweight Brake Cam
67197_01
Lightweight Outdrives
67196_01
Lightweight Wheel Hex Hub
67195_01
Lightweight Steering Post
67191_01
Lightweight 43t Spiral Bevel Gear
67190_01
Lightweight Spur Gear 48 Tooth
Source : HB & RCEASY
