Factory Team Associated RC8B
09-4-13 15:23| 发布者: admin| 查看: 3153| 评论: 0
AE 的Factory Team RC8B 继承了 RC8 的优良车架,再加上大量的升级和改造,经过51位顶尖工程师和车手合力研发而成. 全新的RC8B 使用了 Factory Team 16mm 大容量避震, 5mm 7075 蓝色油压架和悬挂碼, 设备箱也作出修改,力求让重心分布更理想,转向角度也作出优化,RC8B的赛道表现得到大幅提升!Factory Team(FT) 是AE顶级车款系列,从TC3到今日的RC8B,Factory Team的车架在世界级赛事中都是A Final常客,如果最近想入手AE的越野车,不妨考虑FT版本的RC8B。
Factory Team RC8B Kit Features:
- Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
- Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
- New 5mm 7075 blue aluminium shock towers allow the driver to stand the shock angle up for a more aggressive suspension
- Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
- 7075 blue aluminium suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
- Optimized steering geometry for more consistency and reduced bump-steer
- Updated wing mount with additional clearance for 16mm shocks
- Molded composite radio tray includes optional forward placement battery box for increased steering
- Molded composite front and rear chassis braces
- Tough steel-alloy shock stand-offs
- Factory Team 83mm big wheels included
- Machined aluminium racing clutch shoes
- Lightweight engine mounts
- Factory Team 7075 blue aluminium one-piece top plate
- Light-weight 3mm hard-anodized chassis
- 4.30:1 ratio gearboxes for maximum punch
- Heatsink brake discs with “FFC” Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
- Two-piece split-centre diff mount allows quick and easy access to the centre diff
- Caster blocks adjust 14, 16, or 18 degrees with molded inserts
- 3.5mm light CVA drivetrain with full ball bearings
- Rear molded CVA boots to keep dirt and mud out of rear joints
- Blue aluminium hexes and nylon locking wheel nut
Source: Associated [rc10.com] & Redrc.net
