Proline - Suburbs 电越后轮胎
09-5-18 18:39| 发布者: BAMBOO| 查看: 2310| 评论: 0
ProLine 推出新款电越后轮胎——Suburbs ,有 M3 (松软路面) 、MX (blue-groove/high heat) 和 MC (粘土) 三种不同配方的款式以适合不同路面使用。在 2008 ROAR 1:10 Off-Road Nationals赛事中, Ryan Cavalieri 就是使用Proline Suburbs系列轮胎夺得2wd Mod Buggy 好成绩 。最近电越赛事在国内也逐渐流行,相信Proline这个新产品会受到欢迎。
Features:
  • Available in M3 and new MX blue-groove compound and new MC clay compound.
  • National Championship winning compound and tread design
  • Inner and outer radius rib tread for increased corner holding and predictable side-bite.
  • Internal carcass webbing resist tire expansion under acceleration and deceleration
  • Internal sidewall ribbing maintains sidewall structure in extreme traction conditions for greater corner control
  • Tread height is predictable, aggressive, and long-lasting for use on a variety of blue-groove track and surfaces where you would typically run soft compound tires
  • Single stage firm foam inserts
  • Pro-Line branded laser etched sidewall detail
  • Made in the USA
M3 Compound (green dot)
  • Perfect for those loose dirt track wet or dry.
  • Works great for cooler track temperatures.
MX Compound (double orange dot)
  • High-heat/blue groove compound
  • Works best on clean surfaces
  • Long wearing on the most abrasive tracks
  • Forms to track surface for unmatched predictability
MC Compound (purple dot)
  • Great for indoor clay surface
  • Prefers low track temperatures/wet surfaces
  • Receptive to the use of traction additives
“I was amazed at how well the M3 compound performed at my local track. Never before has a tire outperformed the HoleShot until now. It’s the new tire of choice for my local track,” team driver Chad Parks.
“The MX compound is amazing. I race at a super high bite, high heat, blue-groove track and the MX compound outlasts and outperforms anything else I’ve tested,” says Pro-Line team driver Scott Spears.
“I’ve run every clay compound tread on the market. By far, the new MC compound from Pro-Line was way beyond anything else I have ever ran. I know that you too will experience what I did on clay with the new MC compound,” Eric Schutt, Pro-Line enthusiast.
Tire Spec :
  • Height: 3.35″ (85mm)
  • Width: 1.66″ (42mm)
  • Mounting Bead: 2.2″ (56mm)
  • Weight: 40.0g
Source : Proline
