SANWA - MX-3 FG FHSS 2.4GHZ
09-5-26 22:34| 发布者: BAMBOO| 查看: 4414| 评论: 1
Sanwa 的MX-3 遥控器是一款有良好口碑的高性价比遥控,入门和中级玩家很多都选择MX-3,现在Sanwa将MX-3加入了流行的2.4G技术,搭配FHSS-2接收机!(Frequency hopping spread spectrum). FHSS 2.4G技术能够在无线电环境杂乱,噪音高的情况下加强传输的安全性。 Sanwa的工程师对这款MX-3进行了不同的测试,从遥控车到遥控船,从越野车到拖头,证实这款遥控是非常可靠,同时适用于多种车款和海模,FHSS 2 2.4GHz 技术也能很好和MX-3各项技能配合,相信这是一款高性价比的MX-3遥控设备!
Features
  • High output power, full range
  • 100% Receiver-forward compatibility. All surface FHSS-2 receivers are compatible with all FHSS-2 transmitters
  • Frequency Hopping Spread Spectrum (FHSS) provides more security in harsh, crowded environments. Output 100mW
  • Fast refresh rate will make you feel “connected” to your car in a way only a digital signal can provide
  • Same great, proven transmitter designs and programmability as the original MX-3 computer radio
  • MX-3FG added feature: an easy-opening door on the front of the TX hides the binding button; now it´s much easier to set the TX-RX radio link
  • Small, lightweight high-performance RX 442FS 4 channel receiver is compatible with all typical hobby servos, both analog and digital. Can be operated with 4.8-6.0V (nominal), no additional parts needed
  • Unique and functional pistol grip transmitter design
  • Well balanced for precise control
  • Non-slip foam steering wheel
  • Adjustable Expo function (ARC)
  • Well placed digital trim levers
  • Low Battery warning
  • Quick Binding and Fail Safe Setup
  • Optimum third channel switch location
  • Incl. 2 SRM-102 3.0 kg servos!
  • 18 models program
Source: rceasy.com
    引用 vannass 09-5-30 19:19
    how much?
