Spektrum的新款DX3S代表了遥控界的最新科技。它的最大特点就是通过信号双向传输,能在遥控器上看到装在车子上的感应器的数据。此功能无论对高手还是新手都非常有意义,可以检测引擎的转速,马达的温度,等等。而且,无需在遥控器安装任何附加设备,一切数据均可在大屏幕上清楚显示。
Key Features
* Integrated telemetry with graphically depicted gauges on transmitter * Monitor your engine or motor’s operating temperature in either Fahrenheit or Celsius * Never let a low battery stop you in your tracks – the DX3S and integrated telemetry lets you watch over your receiver pack’s voltage to keep you in the running * Keep tabs on your engine’s operating range-safe high-rev operation * Includes SR3300T 3-channel receiver with built-in telemetry * Includes free bonus SR300 3-channel DSM sport receiver * Rolling selector user interface for fast, easy programming and setup * 10-model memory * 10-character model naming * 3 grip sizes (small, medium, large) * ModelMatch * Expert and standard modes * Digital trims * Throttle Punch * Steering dual rate * Travel adjust * Servo reverse * Sub trims * Exponential * 3-timer functions * Aux channel mixing * Telemetry alerts * Buzzer adjustments - high, low & off * Screen contrast * Transmitter battery alert * Right hand configuration (only)
