Losi 8ight-T 2.0 RTR 油动Truggy
09-4-17 22:31| 发布者: admin| 查看: 2383| 评论: 0
Losi 的8ight Truggy自上市后一直非常受欢迎,比赛成绩也极为理想,为了改善第一代8ight的一些弱点,Losi推出了2.0版本的8ight越野车和8ight-t卡车,性能再一次大幅度提升,在全球顶尖越野车行列(如Kyosho、Mugen、AE、Xray等品牌)中,Losi绝对占一席为。Losi 8ight 受欢迎的其中一个原因是操控感受极佳,行走流畅,而且有一种电越的快感,很多玩家在玩过Losi后都被征服。为了让更多玩家能参与Losi车的乐趣,Losi公司推出RTR(Ready to Run, 买来即玩)8ight-t 2.0版本的油动卡车,这辆RTR可以说不像某些品牌的RTR只能作为娱乐,Losi的RTR 绝对是可以用作竞赛的高配置RTR,除了适合入门到中级玩家外,相信部分高级玩家也会把这辆RTR作为Truggy参赛车。
我们来看看这辆RTR的配置,搭载Spektrum’s DX3S 3通道 2.4 GHz DSM 遥控设备!这套设备是带有telemetry技术,可进行多功能遥测,例如检测发动机温度、车速等数据,装备1400mAh NiMH 接收电池。除了有高级的遥控设备外,车架在8ight-t 2.0基础上作出了一些修改,车架长度被加长,悬挂摇臂也进行了加长,全面提升车架行走稳定性,新手操控会更容易上手。动力方面搭载一颗28级 Losi 454发动机,同时附送启动台,不用再受手拉之苦。具体配置请大家查看本文下方的官方配置表,Losi这台RTR Truggy,单从数据上看已经令人无可挑剔,实战方面相信以8ight-t kit的战绩,根本无需顾虑,现在最关心的是上市后的零售价,请大家密切留意RCFans特约商家的到货消息!
4mm 厚底板
Features
- Designed with the entry-level driver in mind, the 8ight-T 2.0 RTR comes completely assembled with the wheels, tires, engine and electronics installed
- The included Losi 454 .28-sized performance engine provides the optimum amount of power for dominating a race or bashing in the backyard
- An included Spektrum DX3S 3-channel sport radio with 2.4GHz DSM technology offers the added benefit of integrated telemetry
- The 8ight-T 2.0 RTR includes a custom Starter Box for simple starting time after time
- The extended length chassis offers unmatchable performance and stability for the everyday RTR driver
- A rugged radio tray design simultaneously increases response and reduces stress on the throttle servo by optimizing the position of the servos
- The pre-painted, fully decorated body allows increased airflow to the engine cooling head and also allows easy access to the fuel tank lid
- Lengthened suspension arms with zero offset wheels offer a wider, more stable base, allowing the truggy to maintain outstanding handling over any terrain, especially while cornering
- A high-capacity 1400mAh NiMH receiver battery ensures multiple runs between charges and plenty of power for the on-board electronic components
- Heavy-duty silicone fluid-filled differential cases in the front, rear and centre increase the driveline durability
- Large, heavy-duty brake disks meet your demands to reliably slow down the 8ight-T 2.0 RTR when needed after accelerating to speed
- From backyard fun to on-the-track domination, the race-length shocks greatly enhance suspension travel providing controlled landings and a smooth ride.
Source: Losi [losi.com] & Redrc.net
