Team CORALLY - RDX PHI ‘09
09-4-24 22:25| 发布者: admin| 查看: 1673| 评论: 0
Corally制造的电房在欧美一贯都有支持者,由于Corally的产量以及代理商推广等原因,在中国区域玩Corally电房的人极少。但是Corally的电房绝对可以和其它顶尖电房相提并论。最新的 Team Corally RDX PHI’09 在经过大量的R&D工作以及测试后制作而成,悬挂系统、传动部分都有了性能提升,支持锂电的安放。官方公布的上市日期定在09年5月中,对这辆电房有兴趣的朋友,不妨先研究研究特性,上市后再入手也不晚。
CORALLY RDX PHI ‘09
rdx-phi-09-chassis
rdx-phi-09-detail-1
rdx-phi-09-detail-2
RDX PHI ‘09 SPEC
  • New wishbone mounting blocks for absolute secure, fast and precise (dis)assembly and easy roll center / toe adjustment.
  • Designed to accept both Ni-MH or Li-Po batteries. Graphite battery strap and additional Li-Po battery holders are included in the kit.
  • New High Torque differentials which use a special deep groove thrust bearing and 18 x 2.5 mm chrome steel balls to ensure smooth and long lasting diff action.
  • New lightweight molded bearing holders for easy accessible diffs and adjustable wheelbase.
  • New design and lightweight molded front c-hubs generating improved steering.
  • New design and lightweight molded narrow rear uprights with vertically mounted camber link balls for fine roll center adjustment.
  • New design and lightweight molded narrow steering blocks with longer arms and steering link position. Improved geometry and more steering.
  • New design and lightweight molded steering lever with horizontally mounted steering link balls for fine Ackerman adjustment.
  • Lower overall weight & chassis prepared for the optionally available super low mounted 20 - 40 gram balancing add-on weights.
  • New chassis design with xtra durable graphite construction.
  • Lowered front and rear roll-center making it ideal for low grip situations.
rdx-phi-09-rear-cut
rdx-phi-09-side-cut
Source : Team Corally
