Futaba 无刷 MC950CR 电变和舵机
09-6-20 14:28| 发布者: admin| 查看: 2808| 评论: 0
futabamc950cr Futaba 推出两款无刷产品。第一款是无刷电子变速器 MC950CR ,多个可调参数,可安装散热风扇,具体性能参数有待Futaba公布.另外一款新产品为 BLS151无刷舵机,响应速度快30%,寿命较普通舵机长500%!很惊人的数值!期待这些产品早日上市。 MC950CR Brushless ESC: Extremely adjustable, with the ability to change parameters through your transmitter – no laptop needed Large, isolated solder posts for quicker, safer wire attachment Features an aluminum case, plus heat sink with removable fan
相关阅读
