Kyosho MINI-Z新产品
10-3-3 14:37| 发布者: admin| 查看: 9127| 评论: 0
30901kr_3Kyosho 推出两款Mini遥控车新产品,第一款为 dNaNo-Racer 1:43 MM version (mid-engine)使用 Nissan 350Z Motul Autech 2007th 车壳,第二款产品为MR-03 带Sauber Mercedes C9 No. 61 Le Mans 1987th 车壳。详细资料在本文内dNaNo 新产品,dNaNo使用2.4G遥控设备,车架精度高,操控灵敏,现在香港较多玩家。有兴趣加入Mini车行了的朋友可进入 http://bbs.rcfans.com/forumdisplay.php?fid=6 Kyosho announces a new dNaNo-Racer 1:43 scale in the MM version (mid-engine): the Nissan 350Z Motul Autech 2007th The vehicle has a motherboard with 2.4 GHz wireless technology and an integrated transponder with an unambiguous global ID. By ICS interface this model can be connected on the laptop to make fine adjustments on the regulator. They are controlled precisely on a compact digital servo. By means of a spring plate is connected to the running as a rear axle with the chassis. The force of the motor is transmitted via a standard Kegelraddifferenzials mounted to the drive wheels. In addition, the shine with a sprung independent front suspension.
  • Wheelbase: 61.6 mm
  • Track (front / rear): 40.6 / 40.5 mm
  • Tire (front / rear):
