Protoform P56 油房车壳
10-5-4 08:07| 发布者: admin| 查看: 2459| 评论: 0
protop56-1Protoform推出全新的P56-Nitro sedan 200mm油房车壳,这款车壳属于竞赛级产品,提供强大的下压力以及灵敏的操控反应。详细资料在本文内。Protoform have given us the Exclusive first look at their all new P56-Nitro sedan 200mm body. This body is designed to be a more compact race body, thus offering superior response while giving excellent down force levels. This body adheres to the EFRA “Global Body Spec” rules as well as all ROAR body rules. The large aggressive wing sits upon 2 oversize wing stands that allow for larger wing screws and quick track side adjustments. Two small molded-in shark fins support the outer ends of the wing and prevent distortion at high speed. The P56-N is ROAR approved and is on the IFMAR ‘approved body’ list for this summer’s IFMAR Worlds in Houston TX. Made of high quality lexan, it’s available in 2 weights, ‘Lite’ and an even lighter weight ‘Pro-Lite’. It comes with a protective coating for easy painting. The body has been tested and given a “thumbs up” by racers like Mike Swauger and Scott Kimbrow. The P56-N will be available on May 5/10. Source: Protoform [prolineracing.com] & Redrc.net
相关阅读
