Yokomo B-Max4 电动越野车推出factory kit版本,性能提升外,耐用度也进一步加强,减少损坏的机率。新车包含了大容量避震,铝制舵机保护器、特别版马达座等,详细资料在本文内。The Yokomo B-Max4 has received the factory treatment, upping performance and beefing up the car against crash damage. Included in this new package is the big bore X shock set, aluminium servo saver mount, aluminium center link, special front brace, aluminium main gear cover, special motor mount, advanced stabilizer set, aluminium rear hub carrier (0 degrees), aluminium shock cap ball, aluminium shock ended ball, carbon battery plate & rear X shock springs (Orange/software). This new version was used successfully to clinch the Japanese Championships although driver of the regular B-Max will need no convincing of it’s fantastic capabilities.
B-Max4 Factory features
- 4WD with shaft. Dustproof design
- Centered motor for excellent balance
- Universal center shafts
- Fully adjustable double wishbone suspension
- Fully adjustable aluminium oil dampers
- Ball differentials
- 4 universal drive shafts to the wheels
- Aluminium motor mount
- Adjustable slipper clutch
- Aluminium suspension mount brace on front
- Complete ball bearing set
- Aerodynamic body and wing
ource: CML [cmldistribution.co.uk] & Redrc.net |
