Associated B4.1 Factory Team kit
10-7-7 16:32| 发布者: admin| 查看: 2268| 评论: 0
assob4-1factory-1前两天我们报道过AE推出了厂队版的RC10T4.1新款卡车,AE的当家电动越野车B4也正式推出了厂队4.1版本(B4.1 Factory Team kit),新B4更轻、更快,全面支持锂电和无刷,加入了大量Factory Team 零件,详细Team Associated B4能继续延续AE电越辉煌,详细资料在本文内。 - 4-Time I.F.M.A.R. World Champion and 5-Time R.O.A.R. US National Champion! - Factory Team 0.5° aluminum rear hubs with oversized outer bearing - Ball differential with lightweight outdrives - Factory Team V2 hard-anodized threaded shock bodies with bleed-screw caps - V2 slipper assembly with high-rate spring for more consistent slipper clutch adjustments - Pro-Line Vortex body and wing - Pro-Line M3 Holeshot 2.0 rear and M3 4-rib front tires - CVA drive shafts with pin retainer clips - Durable steel center-drilled front axles - Carbon-fiber battery strap with blue aluminum thumb screws - Optimized suspension setup for use with LiPo batteries - Suspension mounts for 4°, 3.5°, 3°, and 2.5° rear toe included - Blue titanium turnbuckles - Complete set of precision ball bearings - Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts and much more!
