RC4wd ARB T-Rex 60 Differential cover
10-8-7 15:09| 发布者: admin| 查看: 2331| 评论: 0
rc4wdarbRC4wd 和ARB 公司共同推出新款车轴差速盖!这是完全按照实车产品开发复制而成的差速改,适合T-Rex 60塑胶或铝质车轴使用,超高精度!详细资料在本文内。RC4wd has teamed up with ARB 4×4 Accessories to bring you this new cover for their popular axles. This partnership will allow RC4wd to bring many new scale items to the RC market. ARB is well known for there differential covers, and this is a true replica. Designed to fit the T-Rex 60 Plastic or Aluminium axles, the cover is made from CNC machined aluminium with a smooth anodized finish. Source: RC4wd [rc4wd.com]
