KO Propo RSx舵机系列
10-10-20 13:24| 发布者: admin| 查看: 3682| 评论: 0
korsxservo-1KO Propo推出全新的RSx (Racing Servo,竞赛级舵机)系列舵机,这个新系列舵机是KO经过两年研发而成,适合平路和越野车使用,使用新的材料提升舵机整体强度,加入新的程序让舵机性能提升。使用“特别日本铝材”,强度大幅提升,而且重量较钢齿轻30%,强度提高20%,无刷马达,ICS程序系统都被加入到舵机内。详细资料在本文内。These new servos are the result of two years of R&D for both on-road and off-road. The new servo line features all new materials for increased strength and new programming to take advantage of today’s current technology. Internal Improvements: - The servo gears are cut in house for the best Quality Control from “special Japanese aluminum” for superior hardness and wear. This aluminum is 30% lighter and 20% stronger then steel. - The servo amplifier and processor has been re-worked and optimized for Lipo direct voltage but will still operate when used with NiMH cells. - A new core-less motor for the higher voltage is used to further enhance the use of the LiPo technology. - New ICS programming and new software will be available via PC or the RSx setting card. External Improvements: - The middle case is a one-piece machined aluminum part so the gears and gear pins are held properly in place without any plastic insert that will wear out. - The standard RSx features a new upper case redesigned with increased rigidity on the mounting tabs. The H.C. (Hard Case) versions of the RSx include a machined upper case for maximum rigidity.
RSx Response H.C. 30100 (Digital Servo, Speed Type, Hard Case) Voltage: 6V or 7.4V Torque @6V: 200.1 oz-in, 14.5 Kg-cm Torque @7.4V: 242.9 oz-in, 17.6 Kg-cm Speed@6V: 0.07 S @ 60° Speed @ 7.4V: 0.06 S @ 60° Bearings: Yes, DBL Lead Connector: Gold plated Gears: Full metal Weight: 70.5 g Size: 41×37.5×20 mm
RSx Power H.C. 30101 (Digital Servo, Torque Type, Hard Case) Voltage: 6V or 7.4V Torque @6V: 362.9 oz-in, 26.3 Kg-cm Torque @7.4V: 436.1 oz-in, 31.6 Kg-cm Speed@6V: 0.13 S @ 60° Speed @ 7.4V: 0.11 S @ 60° Bearings: Yes, DBL Lead Connector: Gold plated Gears: Full metal Weight: 70.5 g Size: 41×37.5×20 mm
RSx Response 30102 (Digital Servo, Speed Type) Voltage: 6V or 7.4V Torque @6V: 200.1 oz-in, 14.5 Kg-cm Torque @7.4V: 242.9 oz-in, 17.6 Kg-cm Speed@6V: 0.07 S @ 60° Speed @ 7.4V: 0.06 S @ 60° Bearings: Yes, DBL Lead Connector: Gold plated Gears: Full metal Weight: 65.6 g Size: 41×38x20 mm
RSx Response 30103 (Digital Servo, Torque Type) Voltage: 6V or 7.4V Torque @6V: 362.9 oz-in, 26.3 Kg-cm Torque @7.4V: 436.1 oz-in, 31.6 Kg-cm Speed@6V: 0.13 S @ 60° Speed @ 7.4V: 0.11 S @ 60° Bearings: Yes, DBL Lead Connector: Gold plated Gears: Full metal Weight: 65.6 g Size: 41×38x20 mm
Source: KO Propo [kopropo.com]
