HPI McLaren F1 LM 200mm车壳
10-10-21 05:35| 发布者: admin| 查看: 2711| 评论: 0
17547_002p2HPI推出200mm宽度的McLaren F1 LM车壳,适合油房或190mm电房(需要使用带offset轮圈)使用,透明壳,玩家可喷涂自己喜欢的颜色和车花,更多照片在本文内。The McLaren F1 LM is one of the highest performance supercars ever, boasting a rare balance of handling and speed. Powered by a 627 hp V12 engine, it set the record for the fastest production car in the world with a top speed of 240 mph and blistering acceleration. The styling is pure supercar… low and wide with aerodynamics tuned for stability at high speed. Only 106 McLaren F1 cars were built and only 5 of those were the high performance “LM” version that featured a large rear wing and special badging. If you’ve always dreamed of owning a Mclaren F1 LM, grab this 200mm version designed to fit 1/10 scale touring cars. Included with the body is a pre-cut decal sheet that include window lines, headlights, grills, tail lights, official logos and much more, providing your touring car with a realistically finished product. This body is clear so you can paint it in your favorite colors. It fits 200mm touring cars and can also be used on 190mm touring cars with the use of wide offset wheels. Overspray film is included, as well as vinyl window masks to make painting quick and simple. An instruction sheet is included for the decals, and the body has dimple marks for body post drill locations.
17547_004p
17547_003p
17547_005p
