KO Propo PC-101L充电器和BLZ-350无刷电子变速
10-11-3 03:03| 发布者: admin| 查看: 5957| 评论: 0
kopc101l-400x309KOPropo推出新产品.首先是一款充电机PC-101L charger/discharger, 可使用交流、直流电输入,可对NiCD, NiMH, Lipo, Life和Pb充电,输出接头有蕉插和Tamiya接头,另外一款新产品是BLZ-350 无刷电子变速器,适合有感和无感马达使用,还带倒车功能,详细资料在本文内。 PC-101L Features: - Size: 154×150x54mm (excluding protrusions) - Weight: 742g (excluding cords) - Input: AC100~240V/DC11~18V (power supply min 10A) - Battery Types (# cells): LiPo (1-6 cells) / Life (1-6 cells) / NiMH (1-14 cells) / NiCd (1-14 cells) / Pb (2V, 6V, 12V) - Built in balance ports: JST-XH type - Charging Current: 0.1~8A (NiCd/NiMH mode), 0.3~8.0A (Lipo/Life/Pb mode) [0.1A steps] - Discharge Current: 0.1~5.0A [0.1A steps] - Charging Capacity: 1~9900mAh - Charging System: CCCV / Peak-cut Method - Trickle Charge Rate: OFF, 0.05~0.2A - Operation Key: Push Dial / Push Switch - Accessories: AC 100V cord / Various Battery cords / Temp Sensor
