Arrowmax最近推出多款新产品,包括Mugen MRX-5使用的一些升级改装零件,RC专用工具,详细资料在本文内。
Arrowmax have released this new battery plate for the Mugen MRX-5, manufactured from heavy brass to bring the cars center of gravity lower. Weighing in at 39.7grams, it is a direct replacement for the original kit version.
Continuing their releases for the MRX-5 Arrowmax have released these steering turnbuckles for the Mugen car. Made from high quality titanium, they are lightweight yet very strong. Sold in a pair.
New for the Mugen MRX-5 1/8th scale chassis, Arrowmax have released these front CVD wheel axles. Available in three different types of material, you can get them in 7075 aluminium, spring steel and titanium for a choice of lightweight, durable and a combination of both.
The tools keep coming from Arrowmax with the introduciton of this aluminium shock absorber multi tool. Suitable for shocks from different scales and lots of different classes, this CNC machined, lightweight, convenient pliers allows you to securely grasp shock caps from 8mm to 25mm, install 4mm to 7mm pivot balls and clasp 2.5mm to 5.5mm shock rods tightly without damage. Available in purple and black.
Arrowmax have released these front CVD shafts for use on the Mugen MRX-5. Made from spring steel, these shafts are lighter than the kit versions yet remain ultra durable. Also new for the MRX-5 is this aluminium first gear housing that has been machined for extra weight savings.
Arrowmax has your 1/8th buggy or truck, locking wheel nut needs covered with the release of these 17mm fine thread capped wheel nut set. These high precision wheel nuts are flanged and knurled for locking security and feature a closed end to protect from dirt and debris build-up in the axle or hub. CNC machined. Available in Associated , Mugen, Losi, Kyosho, Hot Bodies and Xray vehicles.
Source: Free Max [freemaxmp.com] |
