JConcepts T4.1 Punisher车壳
10-11-21 12:15| 发布者: admin| 查看: 2065| 评论: 0
jconpunit4-11Jconcepts的Punisher系列车壳推出新款式,新款车壳是为Associated T4.1设计的,车壳的空气动力学性能可增加车子的整体下压力,尤其适合高速赛道、高速弯道使用,该产品已经被车手Paul Wynn和Zach Genova在2010 ROAR上使用过,表现极佳!详细资料在本文内The Punisher body by JConcepts for the Associated T4.1 is the meanest, nastiest thing out for 1/10th truck racing. Throw everything you know out the window, the Punisher separates itself from the rest of the bodies on the market with its distinctive styling. Paul Wynn and Zach Genova debut the new JConcepts T4.1 Punisher body in punishing fashion at the 2010 ROAR Region 4 Championship. Every round of qualifying was TQ’d with the Punisher body as well as taking the top two positions in the A-main! This was the first time the new body was raced in public and it didn’t disappoint! Not only is it stylish, but also designed to increase on track performance with its aggressive hood and cab placement for added down force. The bed area is also designed with performance in mind; there are designated areas to cut out to help reduce the dreaded parachute effect and stabilizer fins for added stability on high speed tracks. Features:
