KO Propo RSx设定卡
11-1-21 00:47| 发布者: admin| 查看: 3992| 评论: 0
KO Propo推出RSx设定卡让用户对舵机进行程序化设定,可对舵机的多个参数进行设定,详细设定特征请看下面表格。
Parameters
Stretch 1 – Set the holding power around neutral
Stretch 2 – Set the holding power other then neutral
Power – Set the max power of the servo
Punch – Set the initial movement from neutral
Deadband – Set the width of the neutral for the servo
Brakes – Set the servoʼs stopping holding power
Model reset – Rest to the factory default settings
Model Copy – Copy model memories.
Source: KO Propo [kopropo.com] & Redrc.net
