KM HK-1 Evolution油房
11-2-15 17:37| 发布者: admin| 查看: 4878| 评论: 4
来自香港的KM Racing推出HK-1 Evolution油房,这是HK-1的全升级版本,包括全铝制皮带齿轮、避震、中轴等都进行了升级,请看详细的列表。
Full list of optionals included
- Full car aluminium parts using A7075-T6 with special hard coating.
- Full car equip with aluminium hard coated pulleys
- Telfon coated aluminium front & rear shocks
- Full bearings with two ceramic bearings for two speed.
- Titanium 64Ti turnbuckle.
- Titanium 64Ti middle shaft.
- Front spring steel universal shaft.
- KM special ultra light weight clutch system.
- Aluminium solid axle.
- KM carbon brake plate with special high friction brake pad.
- Aluminium hex type servo saver.
- Full car equip with low friction belts
- Carbon & aluminium brake arm.
- Carbon battery plate.
- Carbon middle belt stand.
- Carbon middle mount collar.
- Carbon 2 speed shaft collar.
- Carbon rear stiffener.
- Alum. full set steering servo horn
- Alum. full set throttle servo horn
- Full set rear anti-roll bar
- Full set spur gear
- 800 NiMH receiver battery
Source: KM [km-rc.com]
    引用 simsim 11-3-6 03:54
    看那擺臂的質量 和設計
    引用 ·~昶、~~ 11-2-16 10:09
    大概多少钱啊,车架!!!
    引用 宝马 11-2-16 09:27
    ferrarifan: 难道这就是卖BAJA的那个KM???
    那怎么可能
    引用 ferrarifan 11-2-15 18:46
    难道这就是卖BAJA的那个KM???
