Axial 新攀爬车
11-2-21 22:01| 发布者: admin| 查看: 4292| 评论: 27
Axial正在开发新的攀爬车,请看来自海外同行的介绍:
A single image of a new rock crawler was leaked after a preproduction model was seen at the full-size off-road race known as the King of the Hammers. The King of the Hammers is a truly unique race that combines high speed desert racing with extreme rock crawling. This has naturally led to speculation that this new vehicle is designed for that sort of action–racing and crawling.  From what we can tell, this vehicle has a molded plastic cage and a new chassis. The axles may also be new. As we learn more from Axial, we’ll be sure to pass the info on to you. It’s worth noting that it appears that the following companies are somehow involved in this project: TJM, Griffin Radiator, Poison Spider, Corbeau and RDC.
    引用 深圳跃哥 17-8-26 13:27
    怎么看不到照片
    引用 越野80 11-2-25 13:59
    有人组织团购吗??????????????????????????
    引用 天很蓝 11-2-23 16:24
    好看呀、、、
    引用 长风大侠 11-2-23 13:21
    有细节,仿真爬车不错~!
    引用 帝国复兴 11-2-23 09:46
    必须入手~~~ 耐心的等。
    引用 even107 11-2-23 08:42
    这个爬车很毒啊  金属件再多点更给力
    引用 熊铁柱 11-2-22 19:34
    现在国内有售没?大概价格多少?
    引用 阿阿道夫 11-2-22 19:18
    好漂亮的车壳啊!不过 ...
    引用 "宾宾 11-2-22 18:36
    绝对该入手的车。。。。
    引用 vmashimaro 11-2-22 17:49
    性能爬恐怕还谈不上~不过样子已经很毒了~要存钱了~
    引用 lh04147261452 11-2-22 15:15
    钱啊~~~~花不完地花啊~~~~~
    引用 海峡的风 11-2-22 14:58
    看来又要出手了。。。。
    引用 ww3592 11-2-22 14:38
    等到买这个车
    引用 vision 11-2-22 14:31
    總結:designed for that sort of action–racing and crawling
    引用 滇月和风 11-2-22 14:27
    yuhanbaby: 稳定性不知道如何。看如此车身高度,如果没有一定的车身宽度,竞速就算了,转弯必翻。
    竞速???!!!你赢了!
    引用 jianglu119 11-2-22 12:45
    更新真是快啊
    有首歌可以改编一下“我还来不及,又出新产品”
    引用 情兽太累 11-2-22 12:42
    金属版本更帅,哈哈
    引用 蓝天上的鹰 11-2-22 12:06
    真不错这车
    引用 行在风 11-2-22 10:55
    比SCX10更性能的仿真爬!真是我喜欢什么,就有什么啊!
    引用 qq395422218 11-2-22 10:35
    这车 必入
    查看全部评论(27)
