AKA R-Line越野车轮胎
11-3-5 23:49| 发布者: admin| 查看: 3590| 评论: 0
AKA推出R-Line系列1/8越野车轮胎(已粘合),R-Line系列使用世界冠军款式轮圈,内胎使用AKA新研发的产品,世界冠军Cody King也使用这款内胎(红色软材),除了越野轮胎,AKA也对他们原有的短途卡车轮胎进行了升级换代,AKA的R-Line新产品让车子的行走更稳定,地形适应能力更强,属于竞赛级产品。
R-Line的短途卡车轮胎系列
http://www.shortcourse.eu/wp-content/uploads/2011/03/AKAR-LineSC.jpg
AKA have announced the update of all their current 1:10 SC tire and insert combos with their new red insert. The fluted I.D. of the soft red insert allows it to absorb the heavy hits while still having enough internal structure to retain it’s shape and stiffness in the turns to keep corner speeds up. The result is more consistent handling on a wider variety of surfaces with less compromise. R-Line tire and insert combos will be replacing their current tire and insert combo tires and they will be discontinuing the older numbers as supplies run out.
Source: AKA [raceaka.com] & Redrc.net
