雷虎8KT EP 2.4GHz卡丁车
11-4-7 17:34| 发布者: admin| 查看: 6194| 评论: 8
雷虎(Thunder Tiger)推出一辆电动卡丁遥控车,名为KT8 Kart,比例为1/8,使用密封齿轮箱、小型接收机、和真实卡丁车相同的悬挂设计,估计操控感觉会很特别,路面感觉会非常直接。
Thunder Tiger proudly releases the newly designed KT8 Kart. This 1/8 scale kart is packed with awesome features like a gear differential for stability, a sealed gearbox, an easy-change battery tray and standard micro-sized electronics. On-track handling is managed without any springs and shocks but rather by a tuned flex chassis and suspension mounts – just like the full-size racing karts. The realistic nylon-injected bodywork features a nose fairing, separate side-pods, a steering wheel and a driver’s seat to go along with the light-weight driver figure. Slick rubber tires coupled with high density foam inserts mounted on scale appearance wheels offer excellent gripping power.
  • Awesome Finish – 1/8 scale replica of a competition go kart factory-applied body graphics and pre-painted driver figure. Four additional body decals included for replacement.
  • Rear-biased CG – A rear biased center of gravity allows stable handling even on unprepared track surfaces.
  • Real Karting Feel – Rear-mounted motor with rear wheel drive system provides exceptional acceleration, top speed and awesome cornering.
  • Durable Parts – Front fairing and side pods are made of durable, flexible nylon-injected material designed to withstand hard impacts.
  • High-Grip Tires – Equipped with scale slick rubber tires featuring high density foam inserts for great traction. Tread wear indicators let you know when it’s time for new tires.
  • Easy Maintenance – The kart features a low number of parts allowing for simple operation and easy maintenance.
Specifications:
  • Length: 256 mm
  • Width: 195 mm
  • Wheelbase: 6.14”/156 mm
  • Tire Diameter: 48 mm
  • Final Drive Ratio: 9.79:1 (22T pinion/60T spur)
Source : Thunder Tiger & Rceasy.com
    引用 la100ji100 11-4-9 12:32
    上次模型展看了   怎么到现在还没上市
    引用 x蜗牛增压x 11-4-8 20:43
    卡哇伊呢!
    引用 林四海 11-4-8 12:27
    如果在800以内还可以考虑 超过1000 哎一声叹息了
    引用 leiguoxiong 11-4-8 09:23
    如果手脚能动那还差不 ...
    引用 amuro1980 11-4-8 09:03
    居然还说和真KART是一样的设计,我是没见过真KART有独立悬挂的。骗人的技术真烂。
    引用 林四海 11-4-7 23:29
    世界上最丑的卡丁车问世了哈哈哈
    引用 zhangdf118 11-4-7 21:09
    这个车都不知道出来多少年了哦!~
    引用 林四海 11-4-7 20:50
    还能再丑了吧 和经商比就是垃圾呵呵呵 不知道为什么雷虎卖的那么贵
    查看全部评论(8)
