HPI Toyota Spriter Trueno Coupe AE86车壳
11-4-14 23:18| 发布者: admin| 查看: 4235| 评论: 4
HPI推出Toyota Spriter Trueno Coupe AE86 190mm车壳,相信大家都很熟悉AE86吧,HPI这款产品是获得Toyota官方授权制造的,像真度和细节处理得非常好,适合各款1/10电动房车使用(包括漂移车)。
1/10 Touring Car Size (190mm) Approved by TOYOTA MOTOR CORPORATION.
HPI Racing’s 190mm version of the legendary drifter, the Toyota Trueno AE86!
The AE86 Trueno is one of the most famous rear wheel drive drift cars, and it has gained a huge following due to the international popularity of drifting. Our true-to-life 1/10th scale replica captures all of the details that make the Trueno a fan favourite.
Included with the clear bodyshell is a huge pre-cut vinyl decal sheet with window lines, headlights, grilles, tail lights, HPI logos and extra “tuner” decals for a realistic look. A convenient overspray film is included, as well as vinyl window masks to make painting quick and easy. To make mounting the body simple, an instruction sheet is included and the body has dimple marks for drill locations. The 190mm width is perfect for most electric touring cars.
  • Photorealistic die-cut premium vinyl decals include window frames, headlight, grille, tail lights, official logos and more!
  • Clear overspray film and pre-cut vinyl window masks make painting simple and quick
  • A decal instruction sheet is included for precise decal placement to create a winning car in no time
  • Each HPI body has dimple marks for body post drilling locations
  • An optional, realistic spoiler is provided with the body
  • Moulded from 0.030″ clear polycarbonate plastic for durability and long life
  • This is an officially licensed replica!
    引用 ray9394 11-4-20 12:59
    3箱的不是叫AE86,应该是AE85。
    引用 Kieeo 11-4-16 19:59
    无爱~~
    引用 sking016 11-4-15 11:35
    还是两厢的好看
    引用 250527437 11-4-15 08:21
    又是这包围 难看
