Losi 22 RTR 2wd电越
11-7-1 15:38| 发布者: admin| 查看: 5464| 评论: 3
Team Losi推出22 RTR 2wd电动越野车,基于TLR 22 Kit版本的基础研发而成。如果玩家希望升级至TLR 22也非常简单,零件全部通用。22 RTR装备losi无刷和电子变速,Spektrum DX3E遥控和SR300接收机,大扭力舵机,虽然是RTR,但是这款产品的性能绝对具备竞赛级的能力。使用后置马达设定,只需要购买相应的配件可以转换为中置马达设定。
欢迎进入RCFans越野车讨论区参与讨论
http://www.rcfans.com/bbs/forum.php?mod=forumdisplay&fid=5
Features
- Spektrum DX3E Transmitter
- Spektrum SR300 DSM receiver
- Race-worthy Losi 13.5T sensorless brushless system
- Losi extra high torque steering servo
- 7075-T6 Aluminium chassis
- Removable plastic dirt guards
- Maximised chassis length and wheelbase
- Supports multiple battery configurations
- Weight balanced and centralised
- Improved component durability through materials and design
- Comes in a rear motor configuration
- Fully adjustable caster via optional spindle carriers
- Allows for fine tune adjustment for on/off-power steering
- Hard anodised 12mm shocks with bladder compensation
- Large bore shocks with plastic caps
- Provides increased handling over bumps and improves handling
- Molded shock tool included
- Best in class front nose clearance
- Improved handling entering ad exiting steep jumps
- Adjustable front kick from 20 to 25 degrees with optional parts
- All metric hardware
- Unsurpassed tuning and adjustability
- Mounted front and rear tyres
- 3.5mm turnbuckles for increased strength
http://www.redrc.net/wp-content/uploads/2011/06/Losi22RTR-1.jpg
http://www.redrc.net/wp-content/uploads/2011/06/Losi22RTR-3.jpg
http://www.redrc.net/wp-content/uploads/2011/06/Losi22RTR-4.jpg
http://www.redrc.net/wp-content/uploads/2011/06/Losi22RTR-5.jpg
Source: Horizon Hobby UK [horizonhobby.co.uk]
    引用 疯狂的max 22-8-7 00:00
    无刷是13.5t
    引用 super_弟 11-7-3 20:51
    想知道无刷配置
    引用 晴忝尛豬 11-7-2 05:22
    这布局看得我菊花一紧~~
