Xray RX8头铝制防倾杆固定座
11-8-9 00:53| 发布者: admin| 查看: 6193| 评论: 0
使用了这款铝制防倾杆的RX8 1/8平路车,在调整downstop的时候不会影响防倾杆的设定,还可以对轴距进行调整。
欢迎进入RCFans油车讨论区参与讨论
The aluminum front anti-roll bar for the XRAY RX8 allows you to adjust the anti-roll bar independently from downstop, so that the downstop setting does not influence the performance of the anti-roll bar and vice versa.An added feature of this set is that you can also adjust the wheelbase. The anti-roll bar moves together with the front arm, and wheelbase adjustment shims can be added either in front of the anti-roll bar (to shorten the wheelbase) or behind the arm (to lengthen the wheelbase).
#342401 Downstop Independent Alu Front Anti-Roll Bar
• Alu front anti-roll bar for XRAY RX8
• Independent adjustment of anti-roll bar vs. downstop
• Easy wheelbase adjustment
• CNC-machined
• Swiss 7075 T6 aluminum
