Hot Bodies TCX option parts
11-8-10 23:54| 发布者: admin| 查看: 3751| 评论: 0
Hot Bodies即将推出几款升级零件(Option parts)给TCX 1/10电动房车使用。包括加长的轴杯,可用在头差速,让玩家可使用44mm传动轴代替原来的46mm。一体化轴套,铝制紫色外观,能提高拆装的效率和提升零件的耐用度。HB还推出了6孔 1.1mm Teflon避震活塞。相信HB TCX电房性能有了进一步提升!
欢迎进入RCFans电车讨论区参与讨论
SOLID AXLE LONG CUP (POM/2PCS)
# 68770
This set of longer lightweight POM outdrive cups fit the front diff or spool on the HB TCX, allowing racers to use the 44mm driveshaft instead of the 46mm driveshaft.
UNIVERSAL AXLE PIN COVER (2PCS)
# 68759
This anodized aluminium collar replaces the set screw in the universal axle for quicker axle rebuilds and increased durability. It surrounds the pin to prevent it from slipping out.
SHOCK PISTON 6 HOLES (1.1mm/PTFE/2PCS)
# 68768
Tune your TCX for any track condition with the help of this pair of PTFE 6-hole shock pistons featuring 1.1mm holes.
Includes a pair of 6.2 x 3 x 2mm spacers and a shock rod guide, both made from PTFE.
Also available is the #68765 3-hole shock pistons with 1.2mm holes.Fits the TCX as well as all older HB Cyclone and Cyclone TC universal axles.
Source: HPI Europe [hpieurope.com]
相关阅读
