KM Racing引擎轴承专用工具
11-8-16 00:06| 发布者: admin| 查看: 5640| 评论: 0
KM Racing推出引擎轴承拆装专用工具。使用这套工具拆装引擎轴承变得轻松简便。适合所有12级和21级引擎使用。
New from KM Racing is this engine bearing tool kit that allows the easy installation and removal of bearings. Made from high quality steel it is easy to use and suitable for all .12 and .21 size engines using the company’s different range of adapters and collets. The adapter and collet sets is sold separately and comes in 11.5mm and 11.9 – 12mm versions for .12 engines and in 14mm and 14.4mm versions for .21 engines.
http://www.redrc.net/wp-content/uploads/2011/08/KMBearingTool-2.jpg
http://www.redrc.net/wp-content/uploads/2011/08/KMBearingTool-3.jpg
http://www.redrc.net/wp-content/uploads/2011/08/KMBearingTool-4.jpg
