Losi Mini 8ight
11-9-16 00:24| 发布者: admin| 查看: 5881| 评论: 6
Team Losi推出迷你版8ight越野车,车架是基于1/8车架开发的。迷你版8ight使用无刷动力(4500Kv马达),1/14比例,RTR产品装备Spekturm 2.4G遥控设备、NiMH电池(7.2V 1100mAh)、充电器,玩家买回家充好电就能马上启动车子。
Length: 292mm (11.49 in)
Width: 204mm  (8.03 in)
Wheelbase:    186mm  (7.32 in)
Height: 110mm (4.33 in) at ride height
Weight: 0.98 kg  (2.15 lb) with battery
Motor: 4500Kv brushless motor
Speed Control: Brushless
Radio:             Spektrum™ 2.4GHz DSM Technology
Batteries:        7.2V NiMH with EC2™ connector
Kit/RTR:         Ready-To-Run (RTR)
Shock Type: Aluminium, threaded, oil-filled
Body:  Custom decorated available in 2 colors
Tyre Type: Mini Kingpin™ Buggy
Ball Bearings: Complete
  • Water-resistant brushless ESC
  • 4500Kv brushless motor
  • Spektrum SR300 receiver with 2.4GHz DSM technology
  • 7.2V 1100mAh NiMH battery pack with EC2™ connectors
  • 4WD shaft-driven drivetrain
  • Front and rear metal gear differentials
  • Mini servo with saver
  • Aluminium, threaded oil-filled, coil-over shocks
  • Heavy duty, 2.5mm anodised aluminium chassis
  • Mini Kingpin™ treaded tires
  • 2.5mm aluminium shock towers
  • 12mm wheel hexes
  • Aluminium motor mount
  • Heavy-duty adjustable turnbuckles
  • Chassis dirt guards
    引用 ben.sun 11-9-20 10:56
    USD250.00
    引用 ben.sun 11-9-16 14:08
    多少米呀?
    引用 zch 11-9-16 11:39
    这个比例轮胎怎么配啊
    引用 leehom429 11-9-16 09:51
    东西不错啊~
    引用 WML 11-9-16 09:16
    支持往小比例发展!!!!有利于RC的普及化。最好配件可以便宜点。
    引用 11-9-16 07:57
    真卡哇伊啊   大的买不起 这个必须来一个
    查看全部评论(6)
