Kyosho DRX Ford Fiesta Ready Set
11-9-22 23:29| 发布者: admin| 查看: 8579| 评论: 6
Kyosho(京商)宣布推出油动4WD拉力遥控车,DRX Ford Fiesta Ready Set。装备2.4G遥控设备,三差速传动系统、18级引擎,相信这是一款入门级的跑街或者跑拉力的好车!预计在10月上市。
Features:
  • 3 Differential Drive System – Long wheel base chassis with 3-differential full-time 4WD realizes the low center of gravity and excellent suspension for great running performance on any type of surface.
  • Fully Interchangeable – Fully interchangeable suspension arms and knuckles realize economical and efficient parts maintenance.
  • Syncro 2.4Ghz – A stylish FHSS 2.4Ghz rc system featuring dual rate function all pre-installed in the DRX, also features a 4 channel receiver for future expansions.
  • Rock Guard – Knuckle design features rock guards that prevent dirt and stones getting inside and locking the wheels up unexpectedly. In the heat of racing battle, this is an essential design feature.
  • Independent Suspension – Specially designed 4-wheel independent suspension delivers plenty of stroke even on the upward side for stable high-speed surface tracing and powerful running performance.
  • Rally Pattern Tires – Rally pattern pneumatic rubber tires and wheels compliment the scale appearance of the body and its separate clear-lens headlights.
  • Clear Headlight Lens – Separate clear lens headlights included add a detailed finish to the scale realistic body and decals.
  • 2 Shoe Clutch System – Uses the same separated clutch structure as racing buggies to deliver superior throttle response.
  • Large Capacity Air Filter – Large air cleaner works effectively to extend the maintenance cycle of the engine.
  • No Holes – Downward facing offset of the muffler exit eliminates the need for exhaust holes in the body.
  • Large Oil Filled Shocks – Large capacity oil shocks with chassis height adjustment function are included as standard.
  • Keep the Dirt Out – Dirt resistant radio box can be completely removed with just four screws for easy maintenance.
  • Dual Disk Brakes – Dual disk brakes allow individual brake settings on the front and rear.
  • Large Fuel Tank – 103cc fuel tank delivers run times of more than 10 minutes.
  • Racing Features – Racing design features include a transponder stay and a quick opening fuel tank cap.
  • Unlimited Adjustments – Setting options are available for chassis height, camber, tread, as well as front and rear toe angle.
  • Full Range of Option Parts – Optional clutch springs and clutch shoes provide a variety of power feel settings. Install an optional stabilizer to take performance to an even higher level.
What is a Ready Set
A Readyset is a fully assembled model that includes nearly everything you need to run. Body Color scheme is complete so only consumables like batteries and fuel are required so you can start operating the model without delay.
ReadySet Contents
  • Pre-assembled chassis by Kyosho
  • Completed pre-painted body
  • Mounted GXR.18 engine with recoil starter
  • Special manifold and muffler
  • PERFEX KT-200 2.4Ghz R/C system installed
  • Cross Wrench
Required For Operation
  • AA-size batteries x 12 for R/C system, D-size batteries x 2 for plug heater and fuel are sold separately.
  • R/C Fuel (20%)
  • Glow Plug Heater
  • Fuel Bottle
Available: October 2011
    引用 stone456 12-6-6 11:59
    我勒个去的米了
    引用 凯西 11-10-26 21:38
    现在有上市吗
    引用 luqiaoweitao 11-9-27 12:06
    他应该出款加汽油的,而不是甲醇 ...
    引用 8deepwater 11-9-23 16:56
    呵呵,改ken block 43正好
    引用 MRSix 11-9-23 13:05
    经商又来啦 呵呵
    引用 林四海 11-9-23 00:25
    京商一百年不许变
    查看全部评论(6)
