HPI Baja 5SC SS29
11-10-3 17:15| 发布者: admin| 查看: 4783| 评论: 5
HPI正式推出1/5 Baja汽油车5SC SS29版本,这是一款Kit(需要自行组装)汽油车,装载高性能的29cc两冲程汽油引擎,新的高流量排气管,8000RPM离合器,车速轻松突破40英里/小时,一箱汽油就能行走超过45分钟。
The 1/5th scale Baja 5SC short course truck from HPI has gotten the 29 treatment. The Baja 5SC SS29 comes as an unassembled kit that you get to build from the ground up. If you enjoy the process of custom building your own R/C vehicles, then this is the kit for you. Its more than just a kit version, it’s packed with extra speed and a long list of option parts. The powerplant has been upgraded to the high performance Fuelie 29s engine, coupled to a high flow aluminum tuned pipe with steel tubular header. Combined with the 8,000 RPM clutch, the Baja 5SC SS29 has some serious grunt to help propel it to speeds in excess of 40MPH. Need to quiet things down a bit? They’ve also included a stock can muffler just in case.The powerful Fuelie 29 gasoline engine propels the Baja 5SC SS29 to speeds in excess of 40mph. With a dual-element air filter, easy pullstarting and convenient Torx T-27 screws, it’s easy to keep running on standard pump fuel and 2-cycle engine oil. And best of all, you can run for more than 45 minutes on a single tank of gas!
Super Heavy Duty Parts
Because of the ever-increasing power demands of Baja owners around the world, and the constant desire to cram as much power in the Baja chassis as possible, we’ve added all-new SUPER Heavy Duty drivetrain parts that will make sure the Baja 5SC SS29 can handle extreme conditions and massive power!
The Baja 5SC SS29 follows the HPI innovation of upgraded ‘Super Sport’ models that feature kit versions of popular HPI RTR models, with additional option parts added to enhance the enjoyment of your kit. A long list of option parts are included with the SS version of the Baja 5SC. As you build the kit, you add in the options that come in the box and add your own radio gear (receiver, throttle servo, and receiver battery)
相关阅读
    引用 大黄河流沙 11-10-5 14:19
    NB
    引用 ANHX23 11-10-4 09:27
    保持原价或更低还算有点意义
    引用 chenqiancom 11-10-4 00:37
    HPI真是越来越没创意了!就只能把baja翻过来掉过去的抄!
    引用 kingzw 11-10-3 19:41
    继续炒冷饭
    引用 asukagyh 11-10-3 18:40
    沙发~~~~~好车啊~~~~
    查看全部评论(5)
