Tamiya(田宫)为2012 IFMAR电房世界赛做好充分准备,TRF417X即将面世。增加了车架的扭动性,低速的抓地力更好,一体化马达座代替现有的三片式设计,前后油压架厚度增加至3.5mm,新设计的二楼板,电池固定座,尾齿差也会出现在TRF417X新车上。Tamiya暂时没有公布新车的准确上市日期和定价。
Features: Motor mount allows adjustment of chassis rigidity and new positions of motor attachment holes enable a wider choice of gear ratios to better suit your track or racing class. Damper stays have damper attachment slots to allow fine setting adjustment. Increased thickness of 3.5mm offers improved damper attachment rigidity for greater damper effectiveness. Separately Required Items: ●2-channel R/C unit with ESC. ●Body, tires, motor, battery pack & charger. Item No:4220
5
