JConcepts 推出Finnisher车壳给 TLR22 和 DEX210
11-12-1 14:06| 发布者: admin| 查看: 7253| 评论: 2
JConcepts hit the ground in VaasaFinland with an all new body design specifically for the IFMAR World Championships.  Cleverly named, Finnisher, the unique design quickly rose to the top of the field during competition and proved effective on the ground and in the air.    Designed with aspects learned from the Punisher line of bodies, the Finnisher provides an even more aggressive look with included details which remain crucial to performance.   The Durango DEX210 Finnisher body is a drop fit for a popular and newly released buggy.
With the evolution of race tracks, complicated circuits combining more aggressive jumps and extremely high-speed corners; JConcepts incorporated many features which provide several benefits in the most critical situations.
Increased windshield angle provides a steady force upfront during mid-flight wind gusts on large jumps.   Forward cab placement changes performance / visible bias which helps steering rotation in low traction corners.   The side-pods have been simplified and JC chamfered to remove unwanted changes in height to neutralize the at-speed handling.    The chassis to body fit has been tightened up and with the addition of fastening hook and loop tape, eliminates empty voids that contribute to mid-flight directional changes.   The rear of the cab has a new step feature and a louver which can be trimmed to allow air to escape at the top of the body through its V-shaped design.
In addition to the newly designed body, JConcepts has included 2 of the latest 6.5" wide Hi-Clearance rear wings.
Features:
·         Original - JConcepts Finnisher design
·         Blended wing / body design
·         Includes 2 – 6.5" wide Hi-Clearance wings
·         Clear polycarbonate with protective film
·         Window masks and decal sheet
All bodies are sold clear and are shown painted for advertising purposes only. Tires, wheels and bodies are sold separately, unless otherwise specified.  JConcepts reserves the right to update or make changes to product, packaging or contents.
12
    引用 2.5R飞了 11-12-2 08:21
    210的肚子大了点
    引用 bo68674 11-12-1 23:34
    讲真!个人不认为好睇!
