Much More Hybrid Pro
11-12-1 14:18| 发布者: admin| 查看: 7201| 评论: 8
Much More推出新款Hybird Pro充放电和稳压电源一体机,这款产品在最近日本举行的亚洲房车系列赛( Asian Touring Series)上已经出现。使用微型处理器,两种充电检测,分别是峰值检测和温控。充电最大输出为10A,放电为5A,内置锂电平衡器。这款产品还带24A稳压电源(power supply),两组输出,真是一款全能产品。提供黑色和蓝色供玩家选择。
SPECIFICATIONS
★ All in one design
★ Microprocessor controlled
★ 2 kinds of charge cutoff system : Peak cut(Lithium Voltcut), temperature cut
★ Blue back light LCD display with 16x2 characters
★ 10A charging and 5A discharging with high capacity LiPo,LiFe batteries
★ Individual voltage balancer for Lithium batteries inside
★ Real time individual voltage monitoring (charging and discharging for Lithium batteries)
★ Normal , Storage, Balance charge mode for Lithium batteries
★ Delta-peak sensitivity(NiMh, NiCd)
★ Time limit function
★ Input voltage monitoring
★ Data storage(store up to 5 packs in memory)
★ Micro temp sensor
FEATURES
Dimensions : 142 x 119 x 141mm
Weight : 1300g
NiCd,NiMh No. of cells : 1~18
LiPo,LiFe,Lilo No. of cells : 1~6
Pb Battery voltage : 2~24V
Charge current : 0.1~10.0A(adjustable) *Max 200Watt
Discharge current : 0.1~5.0A(adjustable) *Max 25Watt
DC Input : 11.0-18.0V
AC Input voltage : AC100-240ACV 50~60Hz
                                (Auto adjusting)
Charging Capability : 0~9990mAh
Charging Modes : NiMh, NiCd, LiPo,LiFe,Lilo,Pb
Voltage Threshold/Delta Peak : Default・5~20mV/cell
Thermometer sensor : 20~80 Degrees celsius
Data store : 5 data of batteries
Keys : 4 button
LCD monitor : 16x2lines Blue LCD display
http://www.muchmoreracing.net/us/detail/mm-hbpk_b.htm
    引用 hummervivian 11-12-3 11:03
    加油站么~
    引用 Allan0628 11-12-2 20:30
    样子真难看!
    引用 ss_aa 11-12-2 10:45
    亲~求价格~
    引用 疯狂石头 11-12-1 22:17
    不知道价格得多少啊
    引用 shi995800 11-12-1 20:52
    除了长得丑点
    引用 狙你没商量 11-12-1 15:51
    米货啊
    引用 大冰 11-12-1 15:15
    Nb了,我喜欢一体的
    引用 1051 11-12-1 14:55
    在哪买啊?
    查看全部评论(8)
