JConcepts 2.8″ G-Locs 轮胎和 Rulux轮圈
11-12-15 13:28| 发布者: admin| 查看: 6557| 评论: 3
In Aeronautics, G-Loc is the moment where consciousness is lost. The G-Locs 2.8” tire, by JConcepts is where consciousness begins. The super low-profile, aggressively treaded tire is purpose built for those aggressive speed-runs and specifically for vehicles capable of high-voltage or high-horsepower fun. G-Locs are competition inspired from the ground up to perform straight out of the package. Deep G-Loc tread-depth and style provides the healthy footing for maximum durability and ground pounding asphalt traction. Thick, reinforced tire carcass, with internal overlapping X-braced ribbing provides unparalleled support, reducing unwanted tire expansion, for gained high-speed control. G-Locs, are manufactured using the exclusive ROAR National Championship winning yellow compound for the best gripping performance.
The 2.8″ G-Locs provide elements that combine light-weight, performance and durability with the inclusion of Profiled closed cell inserts. The highly successful insert material made it’s fame on the 1/8th off-road racing circuit and now into the JConcepts 2.8″ line. Feel at ease while doing high-speed runs with the durability and performance of the closed cell material which provides durability and feel when others run short.
The low-profile diameter tire body profile with hefty G-Locs tread, together with the durable Profiled closed cell inserts has revolutionized speed tires for the most popular assortment of vehicles on the market. Your 2.8” equipped vehicle has never been more fun than when paired with a 3s Lipo or buzzing nitro engine and G-Loc tires. Wheelie popping speed combined with G-Locs traction and stability is a combination that is second to none. JConcepts is World Proven Innovation and Design.
Features:
Super low-profile
Overlapping X-braced ribbing
Exclusive, winning, yellow compound
Thin-wall, Profiled closed cell inserts
G-Locs – yellow compound – tire / insert (fits 2.8″ wheel)
Part # – 3056-00
Retail price – $25.00
(fits Traxxas style 2.8″ bead wheel)
2.8″ G-Locs – yellow compound – black wheel – (pre-mounted)
Part # – 3056-3030
Retail price – $35.00
(fits Stampede 4×4 F&R and E-Stampede and E-Rustler 2wd front)
Part # – 3056-3040
(fits E-Stampede and E-Rustler 2wd rear)
12
    引用 WML 11-12-16 09:35
    此轮胎必然重量会上升许多。鉴定完毕。除非牺牲胎皮的厚度来取得平衡。
    引用 shi995800 11-12-15 14:18
    这个设计好,不过相应的胎水黏着部分会不会受力加大
    引用 zch 11-12-15 14:12
    是1/10电卡胎吗?
