Speed Passion Reventon 无刷电子变速器
11-12-22 01:20| 发布者: rcfans| 查看: 7778| 评论: 0
Model Reventon - S Reventon - R Reventon - Pro GT2.0 Pro
Continuous Current /
Burst Current
40A/270A 70A/540A 140A 120A
Maximum Battery
4-9 Cell Ni-xx (NiMh or NiCd) or
2 Cell Li-Po / 2 to 3 Cell Li-Fe
- For 4-6 Cell Ni-xx or 2s Lipo: Use the standard fan supplied with the ESC;
- For 7-9 Cell Ni-xx: The included ESC fan is not compatible with high voltage. ESC fan must be replaced with a high voltage fan or connect the fan to the receiver port (+5V).
Coming 2012
ESC Type Sensored /Sensorless
Motor Type Sensorless or sensored brushless motor
Brushless Motor Limit 9.5T or slower 5.5T or slower 3.5T or slower
Supports Wi-Fi Module
software upgrade  ##
O X
Supports Smart LED
program card with USB
software upgrade
O X
Supports 2.4G held-set for
program setting  **
O X
Supports Bluetooth module
software upgrade  ##
O X
Temperature display  O X
Battery voltage display  O X
Racing Profile Settings Drift 1, Modified 0, Modified 1, Rock Crawler, and Stock 0. Drift1, Modified 0, Modified 1, Rock Crawler, Stock 0, and Stock 1. Coming 2012 Limited Support
Dimensions 33mm X 33mm X 19mm (H)
43 (L) x 35 (W) x 24 (H)
## “Patented” ESC Wireless Control Technology
** "Patented" ESC Radio Access Technology - RAT
详细介绍
http://www.speedpassion.net/reventon/index.asp
12
