Team Orion Advantage Touch充电机
12-1-31 16:26| 发布者: admin| 查看: 17576| 评论: 6
Features:
- Microprocessor controlled advanced digital circuit
- Input Voltage: 11-18VDC and 100-240VAC
- Screen: Spectra TFT 400×240 color touch screen
- Functions: charge, discharge, storage, cycle, balance
- Charging Capability: LiPo/LiFe/LiIon 1-6 cells, NiMH/NiCd 1-15 cells, Pb 2-20V
- Charge Current: adjustable 0.1-5A (variable with number of cells, 50W max)
- Discharge Current: adjustable 0.1-1A (variable with number of cells, 5W max)
- Charge and discharge curve graphic engine
- Charge Assistant
- ATTS Advanced Touch Technology Software
- HPC High Precision Charging System
- Cycle modes: C->D, D->C, D->C->D
- Unique 4-in-1 Balancing Board included (XH, TP/FP, EH, HP/PQ)
- Balancing: adjustable on/off
- Advanced Stand Alone Balancing
- Discharge Cut-off voltage: adjustable
- Multi-Protection System: Input and output reverse polarity protection
- Multi Language Menu (updatable via USB port)
- Charge and discharge data storage for later review
- Adjustable automatic delta-peak charge cutoff
- Temperature monitoring and cut-off (optional)
- TRX-, Deans-, Tamiya-, Crocodile Clips, BEC- and Futaba- charging cables
- Dimensions: L170xW158xH45mm
- Weight: 662g
12
    引用 zengxianyao 12-2-1 10:36
    現在才知道Orion的東西都是OEM! 以後都不買!
    引用 trx 12-2-1 08:29
    垃圾货= =才50W充电功率
    引用 shi995800 12-2-1 00:03
    不好看~~~~~~~~~~
    引用 super_弟 12-1-31 22:39
    估计和b6功能差不多。。。。。。。。。。
    引用 郭与凡 12-1-31 20:20
    怎么所有电器都追求苹果的外形设计,连充都这样。。。
    引用 RANKS 12-1-31 17:35
    样子货。性能垃圾。。。
    查看全部评论(6)
