Futaba 8J 2.4GHz八通道遥控器
12-2-13 20:59| 发布者: admin| 查看: 12519| 评论: 2
System features
  • Futaba S-FHSS 2.4GHz security (also compatible with FHSS)
  • Airplane and Helicopter modes
  • 20 model memory
  • S.Bus-compatible S-FHSS receiver
  • Wireless transfer of model data to and from other 8J transmitters
  • 10-character model and user naming
  • Large (128 x 64 dot) backlit LCD display
  • 8 channels (one variable knob, five 2-position switches, two 3-position switches, one momentary switch, two digital levers)
  • Quick and easy programming using a jog dial and three buttons
  • End point adjustment
  • Dual Rate/Expo (any switch selectable)
  • Servo reversing
  • Sub Trim on all 8 channels
  • Digital Trims
  • Trim Step adjustability
  • ATL (Automatic Travel Limit)
  • Failsafe on all 8 channels
  • Trainer mode
  • Throttle cut
  • Two Count-up/Count-down timers plus integrated timer
  • Model timer
  • Range check mode
  • Servo Monitor/Test
  • Auxiliary Channel switch/level assignability
spacer Airplane Features
  • Six programmable mixes (two with curves)
  • Flaperons with differential rate
  • Flap Trim
  • Differential Ailerons
  • V-tail mixing
  • Elevon
  • Ailevator
  • Snap Roll
  • Elevator/Flap mixing
  • Airbrake/Landing
  • Aileron/Rudder mixing
  • Flap/Elevator mixing
  • Gyro sensitivity
  • Throttle curve (5 points)
  • Pitch curve (5 points)
  • Throttle delay
  • Throttle/Needle mixing (5 points)
  • Idle down (any switch selectable)
spacer Helicopter Features
  • 8 Swash Plate types
  • 5 Flight Conditions (normal, idle up 1, idle up 2, idle up 3, hold)
  • Throttle curve (five points/four curves)
  • Pitch curve (five points/five curves)
  • Throttle hold
  • Hover pitch mixing
  • Hover throttle mixing
  • Gyro sensitivity/mixing
  • Governor setting/mixing
  • Hi/Lo Pitch mixing
  • Offset mixing
  • Condition delay
  • Throttle mixing (swash>throttle)
  • Throttle/Needle mixing (5 point curve)
  • Swash AFR
  • Swash mixing
  • Electronic swash ring
  • Throttle delay
  • Revolution mixing
12
    引用 shi995800 12-2-14 11:01
    只对十字键的设计感兴趣
    引用 momo166 12-2-14 10:38
    以后玩飞机就选它了!性价比是关键!
