HPI Blitz ESE Pro Flux短卡
12-3-17 23:20| 发布者: rcfans| 查看: 9507| 评论: 8
BLITZ ESE FLUX FEATURES AND BENEFITS:
High performance parts are color coded white, cool gray, and warm grey. Not only does this enhance the style of the truck, it lets you know at a glance which part is the high response performance part.
  • The BLITZ ESE PRO FLUX SC features the FLUX Vector 4800kV brushless motor with the FLUX Vapor programmable Electronic Speed Control for blinding speed and instant acceleration off the line!
  • The Blitz ESE PRO FLUX SC comes equipped with an authentic MIP Ball Diff, to provide you with the smoothest and most precise diff action possible to tackle whatever track surface you throw at it.
  • New and improved matte black Mk.8 V2 short course wheel which features a flat inner profile and is designed to use a single inner foam insert. The Mk.8 V2 not only looks great, but also mounts perfectly to the HB Beams tires.
  • The included Beams come in HB’s race winning Pink compound for superior handling and traction on the track, helping your ESE secure that winning spot on the podium.
  • The Blitz ESE PRO FLUX SC includes a durable, clear polycarbonate body ready for your paint scheme. Customize your look with official HPI logos and a variety of graphic elements.
  • Stiffer composite main chassis that quickens the overall response of the truck.
  • Firm front arms give more precise steering feel while the rear arms help free up the truck in corners.
  • Firm shock towers provide less flex, allowing the shocks to do more of the work. Much more responsive to oil and spring changes.
  • Firmer skid plates: jump take-offs and landings are more aggressive. Less compliance means sharper response.
  • Firmer bumpers offer more body protection. Composite front bulkhead: keeps the front end more rigid, allowing for a more precise and responsive front suspension.
  • Aluminum front arm mount: much more precise front suspension action. Set screws keep the aluminum from wearing and also take full advantage of the firm front arms.
  • Aluminum shock bodies provide more precise action for improved chassis response.
  • Aluminum shock top caps provide more precision and response. They also have enhanced bleeding function when building shocks.
  • Aluminum cartridge cap allows a delrin washer to be added between o-rings to reduce shaft deflection and friction.
  • Pre-load lock collars allows locking of collars so preload adjustments don’t change.
  • Firm suspension mounts: more precise alignment of suspension helps make adjustment more noticeable. Parts develop less play over time and take full advantage of the firm rear arms.
  • Trailing vs. Inline: both types of steering blocks are included to help you tailor your truck to your driving style and performance requirements.
  • Heat sink motor mount offers a more rigid mounting of the drivetrain to the motor and has improved cooling potential so you can run those hotter winds even faster.
  • Lightweight slipper/ spur carriers decrease rotating weight in the gearbox and simplify installation.
  • Titanium top shaft: the input shaft to the gearbox is now titanium to further reduce rotating weight and make the most of the powerplant.
  • Aluminum locknuts are used throughout the chassis to lighten the chassis, especially in un-sprung assemblies making the chassis more responsive.
  • 7075 aluminum ball studs further increase responsiveness of the entire suspension and steering systems and remove weight.
  • Titanium turnbuckles greatly decrease the weight of the suspension and add style to your linkages.
  • CNC serrated aluminum, large diameter wheel nuts used at each corner allow the fastest maintenance and offers the most wheel holding torque to prevent wheels from loosening.
  • High impact firm ball cups: more suspension precision and more driver feedback.
  • High quality class 10.9 and class 12.9 hardware used throughout for ease of maintenance and durability.
欢迎进入RCFans 短途卡车讨论区参与讨论
选购短卡产品点击这里
12
    引用 RC高手 12-3-31 10:36
    还不如买普通版,自己装无刷,不过hpi的无刷还不错,效率也挺高的,马达也是四极,不过
    引用 老鼠 12-3-19 13:45
    车我已经装好了!我就关心这个动力多少钱!还有这么暴力的动力装在这车上完全体现不出来啊!根本下不了场地。。。我现在用的是有刷。。
    引用 vookao 12-3-18 21:54
    BLITZ换个壳继续卖,白骨精加套动力又开卖了。。。。能出新的吗?
    引用 蜡包 12-3-18 15:52
    HPI不符合我们国情啊
    引用 super_弟 12-3-18 08:16
    爽!!不知多少米,,,
    引用 nimenhao 12-3-18 08:07
    能报下价吗?~~~~~~~~~
    引用 2.5R飞了 12-3-17 23:57
    真的是比赛啊.....可是现在都喜欢齿差了....铢差不好用啊
    引用 yanzu8109 12-3-17 23:51
    沙发????????
    查看全部评论(8)
