Xray XB4免费升级套件
13-1-18 22:57| 发布者: rcfans| 查看: 4656| 评论: 7
Xray公布将对目前XB4电动越野车玩家提供一份免费升级套件,我们RCFans已经和Xray中国总代理环球模型确认,XB4中国玩家可直接联系玩家购买XB4时候选择的零售店铺,店铺会为玩家作登记并安排发送上述升级套件。免费套件会在未来数周运送至全球各地代理商,之后分发至相应的Xray零售店铺内。 ->点击这里进入Xray品牌专区参与互动
免费升级套件包括:
he package will include:
- Improved 35T diff gears V2 – they have symbol 35 on the back of the gear. Replace both front and rear. The new gear reduces play of the internal satellite gears inside the diff to reduce the risk of damage to the satellite gears.
- Replacement internal diff gears – no change to the parts, just a free spare for those whose gears may have been damaged due to the 35T gear issues. No need to replace if the original ones are undamaged.
- Reinforced front diff bulkhead V2 – to replace front bulkhead to increase durability in crashes.
- Reinforcement for the front shock tower – to reinforce the shock tower in serious crashes.
- Reinforcement for rear roll center positions – to reinforce the camber link assembly on the rear shock tower in serious crashes.
    引用 sgz7697805 13-1-20 22:47
    keailoy: 大厂为什么当初不一次性设计好呢?
    你真搞笑
    引用 keailoy 13-1-20 13:54
    大厂为什么当初不一次性设计好呢?
    引用 SKYHY 13-1-20 13:38
    这才是大厂的风范
    引用 f19811125 13-1-19 15:13
    处理车辆问题的方式真是不同,跟真车召回貌似一个意思了“~”~~呵呵
    引用 f19811125 13-1-19 14:56
    真是没有那个厂商能比~~
    引用 groovyice 13-1-19 14:43
    希望其他厂商也能学习o(≧v≦)o~~
    引用 Myth 13-1-18 23:43
    O YE!!还有免费 XRAY真好!
    查看全部评论(7)
