Tamiya 推出全新电动大脚车
13-5-5 17:33| 发布者: rcfans| 查看: 18928| 评论: 20
Specifications:
Scale: 1/10 scale
Construction type: assembly kit
Terrain use: multi-purpose
Drive-train: 4WD
Drive type: gearbox
Drive line: solid axle
Differential type: gear
Suspension: 4-link
Steering mechanism: direct servo
Shock damper: oil-filled damper x8
Shock damper material: plastic
Tire type: rubber
Tire tread: block-pattern
Body material: Polycarbonate
Chassis material: Aluminum and plastic
Electronic Speed Control (ESC): not included (Tamiya item 45054 TEU-106 recommended)
LED Light buckets: no
LED lights: no
Motor: 540-brushless type x2
Bearings: shielded ball bearing
Adjustable camber: fixed
Adjustable toe angles: fixed
Adjustable ground clearance: fixed
Adjustable gear ratio: fixed
Adjustable wheelbase: fixed
Adjustable track width: fixed
Adjustable shock angle: fixed
Special feature 1: Black resin-covered aluminum shaft side-frames are fitted with black aluminum panels.
Special feature 2: Centrally-positioned gearbox with front and rear aluminum beams.
Special feature 3: Resin upper frame serves as R/C unit cover and battery holder.
Special feature 4: Two 540-motors included.
Special feature 5: Front and rear axle cases contain 3-bevel differential gears and have a 2-level transmission.
Requires: 7.2 battery & charger
Requires: 2-channel radio gear
Requires: electronic speed control (Tamiya item 45054 TEU-106 recommended)
Requires: polycarbonate paint
58549 1/10 R/C Agrios (TXT-2)
Availability: NOW
MSRP: $729.00
http://cdn5.rccaraction.com/wp-content/gallery/tamiya-agrios-txt-2-monster-truck-kit/gallery_58549_10.jpg?2474fa
http://cdn5.rccaraction.com/wp-content/gallery/tamiya-agrios-txt-2-monster-truck-kit/gallery_58549_9.jpg?2474fa
http://cdn9.rccaraction.com/wp-content/gallery/tamiya-agrios-txt-2-monster-truck-kit/gallery_58549_8.jpg?2474fa
http://cdn8.rccaraction.com/wp-content/gallery/tamiya-agrios-txt-2-monster-truck-kit/gallery_58549_7.jpg?2474fa
12
    引用 半空中的泪 13-5-7 20:10
    既不仿真,也没性能,杂种!!!
    引用 shi995800 13-5-7 19:25
    不适合大家的“暴”脾气
    引用 癫疯 13-5-7 15:56
    自古以来 田宫的货玩的就是“范” 性能不适合田宫。。。
    想玩性能还是选TRF吧
    引用 piggypf 13-5-7 08:53
    很弱智的样子……
    引用 jeisa 13-5-6 21:17
    这是攀爬大脚!!!
    引用 冷瞳2011 13-5-6 14:39
    这货能上 两颗无刷吗?
    引用 LICHUN9200 13-5-6 08:17
    没什么新意,车子还是延续了TXT-1的结构,就是避震器安装方法由原来的间接改为直接4条变8条,这样多少在一定程度上能减轻"歪脖子"的问题.这车估计没什么市场.
    引用 54501368max 13-5-6 08:10
    本以为有啥新花样呢,看完发现还没有TXT-1好呢!
    引用 hippo90929 13-5-5 23:00
    729美刀  我去。。。。
       好高级的玩具
    引用 47812325 13-5-5 22:39
    看到第一眼——玩具。。。。
    引用 麻吕丸 13-5-5 22:33
    结构很仿真貌似,不过应该暴力不起来吧。不报什么期望。
    引用 陈威 13-5-5 22:25
    zaku: 有兴趣的可以研究下TXT-1,对TXT-1来说,这是倒退。就一个零件吸引我,就是马达上面的那块可以装风扇的板子。
    同感。
    引用 zaku 13-5-5 22:07
    引用 yushenggang 13-5-5 20:50
    729美金???????????????????????
    引用 纠结啊 13-5-5 19:49
    日本货,垃圾货..............
    引用 wanhaifeng 13-5-5 19:29
    改来改去,还是一样的结构,这也叫全新设计?
    引用 糖豆0520 13-5-5 19:08
    大脚的标准结构 不知道娱乐性如何
    引用 toto163 13-5-5 18:42
    好多塑料件啊。。。这价格过4位数就不厚道了~
    引用 自由大帝 13-5-5 18:21
    看着就没胃口~~~
    引用 潮州仔 13-5-5 18:04
    把铝合金的车架换成塑料的 传动轴的方向还照样是斜的 开起来必定还是歪头
    这样算进步吗??????
    查看全部评论(20)
