G.T. POWER 推出新产品
13-5-5 17:59| 发布者: rcfans| 查看: 8528| 评论: 1
第三款新产品G.T. POWER XDRIVE—607 charger ( 四路7安80瓦 充电器),支持最高7A输出和1A放电。配置了优化软件操作,支持1-6cell锂电,1-15颗Nicd/NiMH电池。
1.        Optimized operating software
2.        High-power and high-performance circuit
3.        Individual voltage balancer for Lithium batteries inside
4.        Balance individual cells on discharge
5.        Accept various types of Lithium battery
6.        Lithium battery ‘Fast’ and ‘Storage’ mode
7.        Maximum safety
8.        Data store/load
9.        Cyclic charging /discharging
10.    PC based analysis using USB communication
Specifications
1.        Operating voltage range: DC 11-18V
2.        Charge power: Max 320 watt(4*80w)
3.        Discharge power: Max 20watt(4*5w)
4.        charge current range:0.1-7A for each pc
5.        Discharge current range:0.1-1A for each pc
6.        Cell count;1-15NiCd/NiMH cells                1-6LiPo/Lilon/LiFe cells                1-10 Lead-Acid cells (2V-20V)
7.        Current Drain for Balancing Lithium: 300mA
8.        Dimension: 230*158*60mm
9.        Net Weight : 995g
最后一款新产品N705 charger (镍氢镍镉充电器),可选充电电压1.5A,3A和5A,适合Nicd和NiMH电池使用。带峰值检测,兼容Tamiya和Futaba接头。
Specifications
1.        AC input :100-240V
2.        DC input :11-18V
3.        Suitable for NiHM, NiCd batteries
4.        Voltage peak detection
5.        Charge current :1.5A,3A,5A
6.        Two output ports: Tamiya port and Futaba-J port
7.        Charge power: Max 40 watts
12
    引用 Jason.An 13-5-6 07:28
    要了何用?
