RB Innovations 汽油车引擎增压器
13-5-6 14:36| 发布者: rcfans| 查看: 12585| 评论: 20
RB Innovations推出1/5汽油遥控车用的机械增压器(Supercharge),无需对现有引擎进行太多改装就能马上提高性能!装置在发动机上的增压装置由皮带与引擎曲轴相连接,从引擎输出轴获得动力来驱动增压器的转子旋转,将空气增压吸入到引擎内,有效提升动力性能!
视频介绍:
http://cdn8.rccaraction.com/wp-content/gallery/rb-innovations-15th-scale-supercharger-system/rbi-scale-supercharger-system-4.jpg?2474fa
http://cdn5.rccaraction.com/wp-content/gallery/rb-innovations-15th-scale-supercharger-system/rbi-scale-supercharger-system-1.png?2474fa
Specs:
  • Drive system ; This system is belt driven from the engines crankshaft using a custom clutch plate. The clutch plate drives our high strength drive belt manufactured from a proprietary blend of materials. This belt allows our high speed 90 degree driveline to be extremely efficient. Power loss due to driveline restrictions is extremely important especially with smaller engines. The main super-charger pulley can be changed for increased overdrive and boost.
  • Impeller Assembly; The heart of this centrifugal supercharger is the impeller with it’s sophisticated design. We manufacture the impellers using an extremely strong but light-weight proprietary aluminum alloy. This process secures close dimensional tolerance and excellent surface finish. Each impeller is dynamically balanced which delivers smooth operation.
  • Housing Assembly; In order to effectively take advantage of impeller design, flow must be efficiently channeled so that pressure rise can be generated with minimal losses. The housing is optimally matched to the impeller flow providing maximum efficiency with this supercharger design. The housing is chrome plated and has O-ring seals. Incorporated into the housing design is the fuel pump pulse line which channels the pulse from the engine to the carburetor. Built into the housing in a nitrous injection port which allows easy nitrous installation.
9450 – $275.00
http://cdn4.rccaraction.com/wp-content/gallery/rb-innovations-15th-scale-supercharger-system/rbi-scale-supercharger-system-3.jpg?2474fa
    引用 志鹏 19-2-17 22:28
    我装过,做工很渣
    引用 hekun0120 13-5-8 23:04
    好像有些抬头。
    引用 Loki张 13-5-8 19:58
    [quote]晴忝尛豬: 之所以是塑料的是因为可以很轻,对动力负担尽可 ...
    引用 COPPELION 13-5-8 08:14
    曲轴箱进气似乎没法装。而且就模型2T引擎这点进气量用得着增压么。
    引用 HY 13-5-7 23:41
    买到国内价格便宜呀
    引用 阿士匹林 13-5-7 14:24
    nyy0223: 汽车的好多地方还是拿皮带连接的呢!看了个新科技视频非要说2句,弄的好像很懂一样的!
    这位朋友别人只是发表个人的意见,你又何必这么大反应呢!我来说两句,个人也是觉得这条带动皮带受 ...
    引用 geniusyys 13-5-7 12:02
    RCfans快和太平洋一样了,评论出人才
    引用 再见优乐美 13-5-7 11:41
    RB的东西都是精品  这个中毒了  必须买
    引用 落难书生 13-5-7 09:34
    那两条皮带,等死。
    引用 liyingxia 13-5-7 09:21
    大哥砸门喷的时候能先好好想想你这句话是否能早到群嘲呗。。。。。。。。看的我想笑啊。
    引用 piggypf 13-5-7 08:57
    挺有兴致的……
    引用 我的大脚 13-5-7 02:28
    如果效果好的话~坐等山寨了~
    引用 一缕络腮胡 13-5-7 01:22
    叶轮使用极强但轻量级的铝合金,保证关闭尺寸公差和优良的表面光洁度。每个叶轮都做动态平衡
    引用 一缕络腮胡 13-5-7 01:20
    华而不实,二冲程汽油机完全没有必要,不过东西做的挺精致的,呵呵
    引用 一缕络腮胡 13-5-7 01:18
    那个叶轮不是塑料的,是压铸的轻质铝合金
    引用 晴忝尛豬 13-5-6 22:20
    xuli666: 橡皮圈驱动,寿命不会太长。转子塑料的,估计增压压力不会太大。
    之所以是塑料的是因为可以很轻,对动力负担尽可能降低,橡皮圈带动也够了,增压力量跟材质基本没有必然关系,不懂机械工学不要误人子弟
    引用 lpfno90060112 13-5-6 22:00
    看着挺强大啊!!
    引用 nyy0223 13-5-6 19:35
    引用 xuli666 13-5-6 16:07
    引用 东旭367 13-5-6 15:17
    nb
    查看全部评论(20)
