DE Racing 1/8和1/10设定轮圈
13-6-12 21:52| 发布者: rcfans| 查看: 5931| 评论: 6
DE Racing推出设定轮圈给1/8和1/10越野类遥控车使用。这套设定轮圈最主要的组件是设定轮,使用橡胶外圈设计,安装在车子后能够精准量度车高、Camber和toe参数。提供不同直径供1/10车子和1/8越野车使用,稍后还会推出适合1/10短卡使用的型号。为了扩大这套轮圈的使用范围,适合不同品牌遥控车使用,DE厂方还配套了不同的轮圈接合器。
http://www.rccaraction.com/wp-content/gallery/de-racing-setup-system/de-racing-setup-station-6.jpg?440dae
http://www.rccaraction.com/wp-content/gallery/de-racing-setup-system/de-racing-setup-station-5.jpg?440dae
http://www.rccaraction.com/wp-content/gallery/de-racing-setup-system/de-racing-setup-station-10.jpg?440dae
http://www.rccaraction.com/wp-content/gallery/de-racing-setup-system/de-racing-setup-station-1.jpg?440dae
Features:
  • Smooth flat face to accurately set camber and toe
  • Wheel diameters match those of tires for setting ride height
  • Unique “roll to set” feature
  • Adapter hubs for use on most current and future models
  • Small size and rugged build for convenient pit bag transport
  • Proudly Made in the U.S.A.
Part Numbers:
DER-SS-LW Large Wheels for 1/8 Buggy / Truggy and Short Course
DER-SS-SM Small Wheels for 1/10 Buggy / Stadium Truck
DER-SS-10 Adapters for 10mm Hex
DER-SS-12S Adapters for 12mm Hex / Short Axle
DER-SS-12L Adapters for 12mm Hex / Long Axle
DER-SS-14S Adapters for 14mm Hex / Short Axle
DER-SS-14L Adapters for 14mm Hex / Long Axle
DER-SS-15 Adapters for 15mm Hex
DER-SS-17 Adapters for 17mm Hex
DER-SS-M Adapters for 5mm Axles
DER-SS-P Adapters for Pin Drive
DER-SS-S Adapters for 3/16″ Axles
    引用 super_弟 13-6-16 15:20
    这个东西其实据高手说用处不大  因为房车在平地跑  轮胎这些细节设定很重要   buggy哪些还是要根据场地来凭感觉好些
    不过还是顶了  还是很有意义的东西
    引用 richmond 13-6-13 13:55
    车壳是亮点
    引用 beckhamsimon 13-6-13 13:33
    冬冬冬: 好'爪地不知怎么
    调车使用,越野车用海绵胎?
    引用 山鼠不下水 13-6-13 03:16
    冬冬冬: 好'爪地不知怎么
    设定轮圈抓神马地啊。。。。你还拿来下地跑圈啊。。。。。只是为了调整车高和各种束角用的。。
    引用 冬冬冬 13-6-13 02:03
    好'爪地不知怎么
    引用 光明三藏 13-6-12 22:14
    好东西啊!!!!!!!!!!!!
    查看全部评论(6)
