 特性
- NEW Front Skid Plate - Reduces wear.
- NEW Lower easy to assemble, wing mount system.
- NEW All black anodised components.
- NEW Gear Differential with hardened steel gears and super hard outputs.
- NEW Hi-Tensile, revised style silver turnbuckles.
- NEW Stronger front steering hub, with fine Kwik Klip Adjustment.
- NEW 12mm Hex Wheels with clean look and industry standard offset.
- NEW Super Strong 7075-T6 Alloy Anti-Squat plate.
- NEW Recessed alloy chassis - Low centre of gravity for LiPo batteries & neater wiring.
- NEW Rear top deck mount - Optimised chassis flex.
- Large range of front to rear battery positions - Allows weight distribution tuning for each track.
- Moulded chassis sides - Fantastic dirt seal with no handling compromise.
- Maximum dimension wing. Superb airflow control and max down force.
- “Super Cool” 7075-T6 Alloy motor plate. Offers a greater surface area and thickness, for improved cooling and rigidity.
- Pro spec 13mm big bore shocks with titanium nitride
shafts, CNC machined 3 hole pistons with recessed ‘e’clips, threaded
collars, twin O ring sealing and diaphragm volume compensation.
- Longer front wishbones - Improved corner speed.
- Stronger front bulkhead and bottom plate.
- 24 piece “Red Seal” ball bearing set.
- PTFE coated shock bodies - Hard, with a super smooth shock action.
- CVA style driveshafts - Increased drive.
- Excellent centre line balance.
- Fully optimised suspension geometry - Fast, consistent handling.
- Moulded gear cover for great spur gear protection.
- Rear motor & three geared transmission - Excellent grip on low traction circuits.
