新特性 – New chassis frame – New arm design – New SFA suspension flex adjustment – Narrow arms with 2mm wheelbase shims – New rear shock mounting positions – New weight balance system – New lightweight slipper clutch plates – New SLS clipper clutch pads – New stronger slipper spring – New +1mm off-set front wheels – Reinforced front and rear bulkheads – Reinforced shock towers – Reinforced outdrive adapters – Reinforced bevel gears – Reinforced ball joints – Updated top deck – Shock O-rings included – Front shock tower protector included |
