Yeah Racing TT-01 转换套件
13-11-14 17:46| 发布者: rcfans| 查看: 9836| 评论: 3
  • Yeah Racing Aluminum Front Lower Arm Set #TTR-001 X 1
  • Yeah Racing Aluminum Rear Lower Arm Set #TTR-002 X 1
  • Yeah Racing Aluminum Front Knuckle Arm #TT01E-006 X 1
  • Yeah Racing Aluminum Rear Hub/Knuckle Arm #TT-007V2 X 1
  • Yeah Racing Aluminum Main Drive Shaft #TT-014V2 X 1
  • Yeah Racing Steel / Aluminum Universal Shaft #TT-015V2 X 2
  • Yeah Racing Arm Pin Set #TTR-016 X 1
  • Yeah Racing Aluminum Rear Box Stiffener #TT-019 X 1
  • Yeah Racing Aluminum Battery Post #TT-021 X 1
  • Yeah Racing Aluminum Front / Rear Propeller Joint Set #TT-022V2 X 1
  • Yeah Racing Aluminum Bumper Plate #TT-040 X 1
  • Yeah Racing Aluminum Bearing Steering Set #TT01E-042 X 1
  • Yeah Racing Aluminum Upper Suspension Mount For Tamiya TT01 #TT-100 X 1
  • Yeah Racing Aluminum Upper Suspension Mount For Tamiya TT01E #TT01E-100 X 1
  • Yeah Racing Aluminum Rear Upper Arm Set #TTR-124 X 1
  • Yeah Racing Aluminum Front Upper Arm Set #TTR-125 X 1
  • Yeah Racing Aluminum Front / Rear Gear Box Joint Set #TT-133 X 2
  • Yeah Racing 4.8mm Delrin Ball End #BN-0009 X 4 Pcs
  • Yeah Racing 3 x 21mm Stainless Steel Turnbuckle #TB-0015 X 2 Pcs
  • Yeah Racing 4.8mm Ball Connector #FB-0002 X 4 Pcs
  • Yeah Racing Shock-Gear 55mm Damper Set #DSG-0055BU X 1
  • Yeah Racing Aluminum Wheel Adapter Set #WA-004 X 1
  • Yeah Racing Ball Bearing Set with Bearing Oil For Tamiya TT-01E #YB0194MX X 1
  • Manual X 1
  • Yeah Racing Sticker X 1
Yeah Racing Aluminum Conversion Kit Ultimate Version Blue For Tamiya TT-01/ TT-01E #CK-TT01/EV2-BU
12
    引用 bgb 13-11-15 18:37
    以前貌似要900多一套的,如果500以内的话可以考虑
    引用 zch 13-11-15 15:11
    是要清仓处理吗,多少钱一套?
    引用 ligen5201314 13-11-14 23:35
    这个不是淘宝早就有卖了的吗
