Yokomo 推出 BD7-2014 电房
13-11-21 20:05| 发布者: rcfans| 查看: 11644| 评论: 1
特性
- 4WD belt-driven competition touring car
- Symmetrical configuration enables an optimal torsion of the chassis.
- Separate aluminum suspension mounts (back-side of the front, and forward-side of the rear)
- Aluminum front solid axle
- Rear gear differentials
- Lightweight plastic cam belt tensioner
- Front and rear stabilizers
- Large aluminum oil shocks
12
    引用 Jason.An 13-11-22 03:05
    好车不错……
